Djay Pro old version
Hello,
I downloaded Djay Pro, but I have an old license key.
Where can I find the good version for my license key please ?
Best regards.
DJay Pro is a new app and you will need to pay for it again via the App Store.
@destmo: Please sent over your License Key to “support@algoriddim”. We’ll find the software it is working with (although it may not be djay Pro).
Djay Pro is DJ Pro. If he HAD DJ Pro as he says then his license will still be good for the current version.
The only way what you said applies is if he had Djay (or DJ LE http://www.algoriddim.com/djay-le) instead.
