I have been experiencing bad crashes using the video automix. It just black out and exit the app. It crashes when deck A video began to mix and blend deck B using transitions. Is there something I can do to fix this? I have been using the same app on Ipad Mini 2 with no issues. Ipad Mini 2 processing power is slower than the Iphone 6. The Iphone 6 should be able to handle it? Please help.
Hey Tommy Lien,
have you sent us the crash with your iPhone? Can you remember when the app crashed, also I would need your time zone.
Thank you for contacting us, will do my best to find the root of the problem.
Cheers,Lukas E.
