Hi guys, is there a way to control DJ Pro from 2 Pioneer CDJ-400? USB connection works, so audio goes the right way, but I cannot press play, cue,… on the Pioneers. Looked everywhere on the site, Googled for answers, but no luck. Anybody knows the answer? Thanks for any help!
bests, Filip
Hey there,
are you working with djay Pro for Windows or Mac?
Cheers,Lukas E.
Hi Lukas,
Mac.
Meanwhile, I figured it out. Wasn’t easy. This is what i did:
I created an aggregate device in Audio Midi setup, with 2 Pioneer CDJ-400. Then select aggregate device in prefs of Djay Pro.
Is there an easier way?
Thanx,
Filip
