You can’t use djay pro and ddj wego4 with iPad Pro 12.9". Why not???
Neither djay2 or djay Pro are working with my iPad Pro 12.9". Are you sure it’s compatible? Pioneers site does not have it listed. wish I’d known before I purchased the WeGo4
So should your software work with my iPad Pro 12.9" and the WeGo4? I can use the software without a controller with no problems.
Can I get confirmation if the 12.9 iPad Pro is supported please?
Hi davold,
the WeGo4 is supported by djay 2 and djay Pro. Every iPad which is allowed to install either djay 2 or djay Pro will work with the WeGo 4.
