djay Pro + Yosemite / El Capitan = High Idle CPU + Energy Impact
Hey Koichi, can’t confirm this in a tech way but it appears that the latest update has addressed the power hungry issue with Djay Pro. Have a basic activity monitor app running and there’s been minimal increase in CPU load while running Djay Pro.
Not much loading = less heat and related issues. Great!!
Enjoying the update, some nice added features and as mentioned, the CPU loads appear to be fixed. Nice work Algoriddim.
Was so close to grabbing SDJ or VDJ…
Same for me!!! My MacBook Pro cooling fan goes creasy ;(
same here. Just starting djay pro and my CPU is at 120% and cooling fan goes crazy
Hi!
I found the solution!
1/ Go to the applications folder
2/ Right click on djay Pro icon
3/ Show Information
4/ Take a pipe to “Show in low resolution”
5/ Run the program
This is nicely working for me, this resolution a bit ugly, but my mac cpu like it:)
I hope i could help
If you like’d to contact me: hegyi.nandi@gmail.com
Hi!
3/ Show Information
5/ Run the program
I hope i could help
