djay 5.4.4 on 14" M1 Pro
no hardware connected, only headphones and bluetooth.
note: this problem does NOT happen on my 2021 16" M1 Max MacBook Pro also with djay 5.4.4, and all the same settings.
Summary of the issue:
whenever we click play, it does a quick jump/skip of a beat, so it’s impossible to manually line up anything. i can upload a video demonstrating the issue.
your support portal “won’t allow pasting a link to that site”,
so here is a url to a video demonstrating the problem,
just remove the whitespace:
https : / / drive. google. com
/file/d/1G1GiEO8fs9glkLOFw_Fs26JbDk88E5qG/view?usp=sharing
Hi @nharkins, I’ve changed your Community privileges so you should now be able to upload your video directly. Please try again. Thanks!
Hey Slak_Jaw, thank you for the reminder, and for adding upload privs (i actually have actively fought spam as part of my day jobs in the past, so it was especially frustrating to be flagged as such)! I’ll upload the video now…
Hi @nharkins, thanks for the video. Please disable the Crossfader FX in the crossfader pop-up menu.
