Hello Algoriddim Support,
I’m using djay with a Pioneer DJM-S5 in DVS mode.
I have enabled the “Reset EQ, FX, and Tempo when loading a new track” option in djay’s settings.
However, when I adjust the physical EQ knobs on the DJM-S5 (for example, turning the LOW EQ down), the EQ settings are not reflected in djay’s software interface.
More importantly, when I load a new track, the physical EQ settings remain applied to the audio. The newly loaded track does not start with a flat EQ, even though the reset option is enabled.
I understand that the physical EQ knobs do not need to return to their center positions. What I want is for the audio of each newly loaded track to start with a flat EQ (12 o’clock / 0 dB), regardless of the previous track’s EQ settings.
Is there any way to achieve this with the DJM-S5 and djay in DVS mode?
If not, is this a limitation of the current integration, and could support for this behavior be considered in a future update?
Thank you.
