Does Djay version 1 work with ios 7?
Yes, djay 1 should work on iOS 7. If you experience any problems as described by Björn, please try restarting your iPad and re-installing the app.
I have an iPhone 4 and have been using “djay” v1.0 for several months under iOS 6 without any problems. I upgraded to iOS 7 and your app has instantly has become utterly broken. More often than not songs won’t load. The duration and time remaining aren’t displayed with the waveform and the turntable arms don’t work. When will you be releasing an update to fix theses issues?
Update: Per Algoriddim tech support; uninstalling and reinstalling the app fixed the problems.
