Double clicking Gain goes maximum or minimum
Running DJay Pro 5.4.2 on Windows with the setting Auto Gain enabled, after loading a track, if I double click the gain knob, it turns gain either to full right (maximum) or to full left (minimum), depending on the initially detected gain.
I’ve noticed this a couple updates ago and it’s strange that nobody else hasn’t reported it. To be clear, this didn’t start with the latest 5.4.2 update, I think it started with 5.3 although I’m not sure.
Hi @Apos, thanks for the details about the issue. I was able to replicate this on my setup. When creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Hi again @Apos, our team has identified the problem and it will be fixed in an upcoming update (likely 5.4.3) Thanks!
Hello @Apos, 5.4.3 was released today and should address this issue. Thanks!
