- Hardware firmware version (e.g. 1.0.1):
- Please consider sharing a short video or screenshots to help clarify your question
Can I drag a folder from finder into DJay Pro and create a Playlist? Or drag a folder with subcrates and create a Playlist Folder? I thought you could, but I wasn’t successful today.
latest version of DJay
Mac M3 Pro
Thanks,
Anthony
Hi @Clinton_Irving, welcome to the Community!
- Yes, you can drag-and-drop a folder from Finder into the My Files source of djay to create a new Folder/Playlist.
- You can also drag-and-drop a folder that contains sub-folders into the My Files source of djay to create a folder with sub-folders.
- However, if you want to do this with the My Collection source of djay, you will first need to create a Playlist then drag-and-drop the folder from Finder into your new My Collection Playlist. In this case, folders with sub-folders are not supported - only the songs in the main folder will be added to the playlist. The songs in the sub-folders will be ignored. I hope that helps!
