Hi. Just bought Pro for windows 10.
Where is the function to set an end / fade point on your Spotify tracks?
Plenty of cue points but not the most important one for (the end cue) so you can let Automix do its job properly. Any advice much appreciated.
Thanks in advance.
Alt + T on a Mac. try that?
Thanks man Didn’t work at first but seems to be now. Cheers
