- Device model *(Mac OS (M4max)
- Version of operating system macOS 15.6.1
- Version of djay 5.5.1:
- Hardware/controllers used Rane Performer
- Hardware firmware version v1.3.0.13
I learned that there is an EQ problem when you turn the RANE Performer on. The EQ settings are not propper the middle.
If you want to control the stems with EQ the stems are not working.
C) EXPECTED RESULTS:
It affects the EQ settings and vice versa the Neural Mix.
D) ACTUAL RESULTS:
My workaround so far: Turn all the eq button one time left right middle to turn the eq to the default middle setting. After this everything works fine. Please fix this.
