Hey guys,
I got a problem regarding my external drive. I cannot search through my hole drive via the finder tab. I reinstalled dj pro but no effect. Via normal finder searching for tracks/ file works fine. So can you help maybe? As well I set my privacy setting for searchlight for the drive and delete it, so that OS X can scan the folder properly. Since then no search in dj pro is available.
cheers,
Maurice
