I would like to set fade to happen at 2:30 on every song with 5 seconds of silence between songs. How can I do this? Thankds
Hey Charles,
thank you very much for contacting us!
Unfortunately this feature is not supported.
Have a nice week, Alex
Hey Luigi,
sorry for the misunderstanding, edited Alex reply. A pause between tracks is not supported by any of our softwares.
But you are not the first user who asked for this feature and I opened an issue in our tracking system.
Thank you for pushing the tropic.
Cheers,Lukas E.
Hi Alex, I have the djay Pro for Mac and can not find the setting to add X seconds pauses between songs. Please advise. Thx!
Thanks Lukas for your prompt response!
I am a tango DJ, but although this issue I’m moving to djay Pro from iTunes because I love your interface, the Spotify interoperability and the outstanding sound quality.
But keep in mind that we are the other half of the DJs (we don’t cross-fade, ha ha, actually to the contrary!). I think somebody suggested negative seconds (-X sec) for the Transition’s Duration… Don’t you think that’s mathematically possible?
I you guys obtain that your software will be unbeatable! Thanks for the great work and product! Abrazo tanguero!
