Filter for "missing tracks" & "Source" on iOS
As we don’t have the Library maintenance tool on iPad, can we at least get:
  1. Filter “missing tracks”
  2. “Source” Filter
    as Filtering options in the library browser and the smart playlists?
This way we can see summary of the missing tracks and deal with them, without having to scroll through the entire library to look for greyed out records. Sometimes iTunes messes syncing, sometimes we cancel some subscription and it leaves orphaned items in the libary. If we can filter for them, it would be easier to do some library maintenance work on iOS devices - be it delete them, or get them from other sources.
“Source” is available as Sorting option, but for smart playlists and maintenance work, it would be very beneficial as Filter too.
Thanks for the suggestion @Kaloyan! Good idea. I have forwarded this to the dev team for consideration.
The “Source” filter would be really nice.
Like when you don’t have internet connection, you could just “show only local files” and filter out “streamed ones”.
Yes I agree bumping this up too
Thanks for bumping this @Mixfit
Request for filtering by Source feature that allows neglecting streaming platforms such as Apple Music and Spotify that restrict STEM manipulation which most DJs heavily use nowadays for seamless and unique blending, mashup and transition. This feature was previously requested on October 2021 and closed on October 2022.
Hi @djshiny, I’ve merged your new topic with this existing one. Please vote above. Thanks!
