It would be great to have the option to filter by [none] or [empty]. This would make it simple to create a smart playlist with tracks you need to check out.
For example, if the rating is empty, no color is set, the genre is missing, the grouping is empty, or any other criteria aren’t met, you could easily filter those tracks out.
