PS.
It could be done with instant doubles and use the filter on one deck with the desired stems activated to play, but I’m looking for a stem assignment like is possible for the effects, bounce loops, etc.
Hi @Brainbox, currently it’s not possible to apply the main deck filters to a specific Neural Mix part. However, you could use one of the Filter FX like Lowpass, Highpass, Bandpass, Auto Filter or LoFi and then route that effect to one of the Neural Mix parts.
I don’t like the filter effects as mentioned, sorry … would it help if I create a suggestion topic?
Understood @Brainbox. Yes, please make a suggestion topic, but use search first in case one already exists. Thanks!
