FIXED: Spotify songs won't load (May 2026)
I used djay this morning until 9:30am. But now, this afternoon (6:30pm), it shows that there are no songs in my Spotify playlists. I’ve already done everything you suggested, and nothing has worked so far.
windows
Djay 5.6.4
Massachusetts
Thanks for the detailed info @Nat and welcome to the community. Sorry to hear that those suggestions haven’t helped. Seems like this is most likely an issue with the streaming servers.
yes same issue still not resolved
HI @duranzzz, welcome to the Community! Sorry to hear you’re experiencing this issue as well.
  1. What type of device are you using?
  2. What OS version?
  3. What djay version?
  4. What country are you in?
Same issue Windows 11 app version 5.6.4 already tried logging out restarting logging back in for Spotify, USA no VPN used
Hi @DarkKilla, welcome to the Community! Thanks for the detailed information.
It looks like it might be down on everything. I just tried on my Android app too. It’s also down. And earlier I was having OAuth issues with developer mode on Spotify. For another custom service I was using. You might want to look into that. Love your app by the way.
Thanks for the info @DarkKilla. This is very helpful
Literally just paid for subscription to cross fade songs off Spotify and just reading this after an hour of troubleshooting. I am unable to get a refund from Apple. I need one. This is bs
Hi @Brett_Rosenberg, welcome to the Community! Sorry to hear you’re experiencing this issue. Our team is looking into this and the issue should be addressed soon. Please note that all subscriptions and refunds are handled directly through the Apple App Store.
not showing up. My card was charged
Don’t worry @Brett_Rosenberg. I recommend you wait try again tomorrow. Also, I suspect the Spotify issue will be fixed soon. This is most likely a temporary server issue.
Hey @Brett_Rosenberg! This hasn’t been an issue until today. Spotify integration is usually reliable. Since everyone is experiencing problems starting today, it appears to be a server issue from Spotify itself. DJay Pro is an dope app.
Thanks @itsRichySmart
I have been having the same issue all day with Spotify integration. Really hope this gets resolved soon.
Iphone 16
ios 26.4.2
djay pro ver. 5.6.4
USA PR
Hi @Chris_A, welcome to the Community! Thanks for sharing
Thanks for the detailed info @duranzzz
I’m using macbook pro, M5, lastest update on both Mac OS and DJpro. My spotify playlists show up in spotify, but not DJpro. I read this entire thread and have done everything suggested, logged off, on, spotify, dj pro, still nothing. Thought I was going crazy till i found this thread. It worked just fine Sunday. I even uninstalled and reinstalled the DJpro app, problem still persists.
I’m having the EXACT same problem and I’m at a gig! Thank God I have Apple Music and Tidal! Please make a fix for this soon! I have 3 more gigs this week. I have tried all the fixes that have been stated in this post. I even created another account.
