Hi @DJGL02, can you please share your actual versions numbers instead of latest?
Device Model (ex. 2020 iPad Air 4th Gen): Version of operating system (ex. iOS 17.3.1): Version of djay (ex. 5.1.3): Hardware Firmware Version (ex. 2.7):
You could also check in djay’s MIDI Learn Tool to see if it is responding to the fader movement:
Alternatively, you could test with a MIDI monitor app to see if the hardware is sending MIDI signals outside of djay: snoize: MIDI Monitor
Thanks @DJGL02. Are you seeing in MIDI response I djay’s MIDI Learn Tool or in MIDI Monitor? If not, then your fader is likely in need of repair or replacement.
