- Device model (e.g. 2020 iPad Air 4th Gen): DDJ-FLX4
- Version of operating system (e.g. macOS 14.4.1): windows 11
- Hardware firmware version (e.g. 1.0.1): 5.6.5
- Please consider sharing a short video or screenshots to help clarify your question
YOUR QUESTION:
- When I connect my FLX4 to my computer it automatilcally swtiches to bluetooth, this issue its not only for me, a friend of mine also bought one and its happenning the same issue, we already changed the usb cable we don’t know what it’s going on
Hi @Raphael_kelevra, welcome to the Community! Thanks for the setup details and issue description.
- Did you recently update to Windows 11 25H2?
- Is this a new issue with djay 5.6.5 or was it also happening on older versions?
- Please update the FLX4 to the latest firmware and retest: DDJ-FLX4 Firmware for Windows - AlphaTheta Help Center
- With the FLX4 connected to your Windows device via USB cable, please share a screenshot of the djay Settings>Audio Devices and Settings>MIDI Devices?
- If you disable Bluetooth on your Windows device, does the FLX4 connect properly?
