I’ve paused on a frame of a lyric video to best demonstrate this bug, when i go into the full screen preview on Video mode, the display is stretched regardless of if I view it in vertical or landscape orientation.
Screen recording: https://mega.nz/file/cWgx2ZJQ#yuqVWZfBquERrDzzb_x4Pytl5nlbrRDfjC-nwsltoRI
- Device model: iPhone 17 Pro
- Version of operating system: iOS 27.2
- Version of djay: 5.6.10
Hi @RagChips, welcome to the Community! Thanks for the screen recording, it shows the problem clearly.
Could you check one setting first? Go to Dashboard > Settings > Advanced > Video > Size to fit and set it to Fit. That keeps the video’s original shape and adds black borders where needed. Fill is the option that stretches it to the screen.
If it’s already on Fit or Auto and full-screen still stretches, let me know which one it was and I’ll pass it on to the team. I hope that helps!
Hi @Slak_Jaw , i’ve tried out all the ‘Size to Fit’ options, including Fill, Fit and Auto but i still have the same issue with all three options.
Thanks for testing all three @RagChips, that’s really helpful.
If Fill, Fit and Auto all look the same in full-screen, the preview isn’t following that setting. I’ll pass this on to the team along with your recording.
One quick question to help narrow it down: does it happen with any video, or just this lyric video? If you’ve got another clip handy (one you shot on your phone, or another music video), try it in full-screen in both portrait and landscape and let me know what you see.
For now, the video preview inside the deck shows the correct shape. If you’re sending video to an external screen, that’s a better place to check the picture than full-screen on the phone. Thanks!
Hi @Slak_Jaw , this issue happens with any other video too, even ones from my camera roll.
@RagChips thanks for checking that. Since it happens with every video, camera-roll clips included, and none of the Size to fit options change it, this sounds like a bug on our side. I’ll send this to the team with your recording and test results.
One more thing that would help: are you sending video to an external screen (AirPlay or HDMI)? If so, is the picture stretched there too?
Thanks again for all the testing, it made this much easier to pin down.
Hi @Slak_Jaw i am only using my phone to display the video, i currently do not have access to an external display that i can project Airplay to, nor do i have a USB-C to HDMI cable handy.
Hi again @RagChips. Our engineering team was able to reproduce this and they are investigating further. I’ll share more news when I have it. Thanks!
