Hi there guys. I’m using a 2014 Macbook pro 13 inch with a 3ghz core I7 And 8GB of ram. I’m using a Mixtrack pro 3 with the software but i’ve noticed that FX 1 DOES NOT WORK. No matter if im using the hardware, or going up to deck 2 and hitting fx 1 enabled, there is no fx that happen. I’ve tried switching to the next or the previous FX and it does not work. This is only happening on deck 2 for some reason, deck 1 still works fine. I’d love to get this working right as i’d be playing some shows soon. Any advice you can offer is helpful. PS. I’ve tried creating my own edit of the midi mapping and it still doesn’t work!
Hi Shaun Ramos,
thank you for your mail.
Can you send us an exemplary video of the explained misbehaviour of the software via support@algoriddim.com?
That would help us tons.
Cheers and sorry for the inconvenience,
