FX Gainer/Riser option? If anyone is familiar my question please help, cheers.
anyone/support know if there is an FX gainer/rise that allows you to slowly raise the bpm before mixing into the next song? I have checked all FX packs and nothing seems to do the trick, any help/tips would be appreciated
