FX output for external hardware settings
Hi team,
Thank you for your amazing software.
Using external mixer, it would be great if we were able to output echo and reverb wet FX to a specific channel like we can output looper sampler or cueing.
This would allow to have post fader/crossfader software FX using external mixer.
If we can also input a selected channel of the sound card to the FX module that’s would be perfect.
That way we could have a send and return FX using the sound card of the external mixer :+1::white_check_mark:.
That’s really what I’m craving at the moment with Djay Pro.
Thank you, cheers :clinking_beer_mugs:.
Thanks for the suggestion @Aligan. I have forwarded this to the dev team for consideration.
