Getting djay from Mac to iPhone 17?
Hello everyone! I cant seem to find a posting that shows how to get djay library, settings, cues etc onto my iphone from my mac. Can anyone lead me to it? Ive never done it but would like to have it on both macos and now on ios.
Hi @MrG, you can use iCloud sync for your hot cues, saved loops and Automix start and end points
There currently is no automated way to sync your playlists between devices. There are, however, some manual options like OneLibrary: What is OneLibrary? | Algoriddim Support
There are some other manual methods discussed in the following topic as well. Many people with Apple devices still prefer to use the iTunes/Music app to manually sync their local music libraries between macOS and iOS.
I appreciate all the info Slak_Jaw!
Lastly, to get all my purchased music or music i have thats on my laptop to my iphone, is the best way going to be using itunes or is there a better method? Im trying to get everything that is on my mac in djay onto the iphone djay. Songs as well.
You’re welcome @MrG. My preference was to use the iTunes/Music app. Other users prefer OneLibrary. Probably best to experiment with a couple of playlists first to see which workflow you prefer.
Sounds good. Thank you once again.
I will give it a shot!
You’re welcome
Hi again @MrG. In the iTunes/Music app make sure to disable the Sync Library setting. In the Music app on your Mac, go to Music > Settings > General and uncheck Sync Library. While it’s on, Music matches your local tracks against the Apple Music catalog, and those matched copies are 256 kbps AAC files, not your originals. This can cause issues with hot cues among other things
Do the same on the iPhone in Settings > Music > Sync Library, then sync your music over cable. Turning it off won’t touch the original files on your Mac.
I think few years back i had that issue with Match and it messed up my library. Thanks for the reminder. I have checked on it and one was still set to “on”. Both now turned off.
You’re welcome
I say go iTunes.
Thanks for the input @LaidbackFred
iTunes has been deprecated years ago, it’s now the Apple Music app.
That said, I really wish djay could do its own direct sync from djay macOS to djay iOS, and sync everything back and forth: tracks, playlists, beatgrids, bpm, key, cue points. And lose the dependency on Apple Music, iCloud, USB sticks etc.
Everything else is just clumsy patchwork: syncing only the tracks+playlists via the stuck-in-2005 Apple Music app, but sync the beatgrids/cuepoints via iCloud, or the equally limited alternative with USB-drives + manually importing OneLibrary which doesn’t support smart playlists, and where djay iOS can import but not export any changes back to your main library…
Hello @certuna
It is still very the same as always. But it’s much faster, very stable.:blush:
I’ve been using it for years, also can sync wirelessly.
I agree, by not syncing library my collection is untouched by Apple Music.
All music on iOS devices are syncing through Mac.
True, you initiate the sync-to-iOS in Finder, but since macOS Catalina the music library/playlists are managed in Apple Music (the app, not the streaming service).
Thanks @LaidbackFred
