Several times. It’s been this way for a few weeks now, which includes normal turing the mac on and off, apps on and off, and even a few system updates.
It started in iTunes. I was building some folders for an upcoming gig, But when I created the folder it disappeared. Seemed odd to me, so I created a second one. Same thing.
finally I got a folder to be created and stay, put a playlist in it and was good to go. All seemed normal and right with the world.
When I turned on DJay later, thats when I noticed the folders that I made but had vanished,
I tried recreating the folders back in iTunes and deleting them out, but all that did was create a new folder, and when I looked at Djay, I could see both folders!
I think I need to lean my research into iTunes at this point I wonder.
It’s really weird. I’m considering uninstalling Djay, and reinstalling it. I’m using Djay pro, would I just redownload it from the App Store for my Macbook, and log in again?
SOLVED! By chance I was looking in my movie folders on iTunes and thats where I saw the mystery playlists! When I created them, they had a movie in the playlist along with regular songs. So iTunes moved the folder to movies and I didn’t realize it!
Thank you for the follow up. Unfortunately I was not able to reproduce your issue with an created playlist folder.
Can you give us further information what folders you are using in iTunes?
