It just doesn’t work for me. However it does work perfectly fine with Serato, so I know its a software issue with Djay. i know how to go to preferences and switch to the Channel 1-2 or channel 3-4 thing. But once I do that, no sound comes out.
No that solved the problem thanks!
you have to go to midi learn and map the controller.
