Headphone Problem while playing with Pioneer DDJ-FLX 4
Previously today I played for 2 hours with main output my Bose speakers (via Bluetooth) and FLX4 as the Pre-Cue ing… There was no problem at all. After I changed the main output to SSL 2 and transmitted the sound to Bose speakers via an aux cable. The pre-Cue was the same in FLX4… After 1 hout the particular problem occured…
Do you think that it has to do with the main output or with SSL2 when it’s used as the main output? The problem is actually in pre-cuing so it does not sound logical to me but you are the experts it is better that you tell me!
One other important note is that, approximately for three months I used my windows based DELL computer with the same setup (flx4 and ssl2) and there was no such a problem! The problem started since I use my Mac!
Thanks for the additional info @Aleksandros_Panayoti. I spoke with engineering. Please note that splitting the audio signal for main audio and for pre-cueing between different devices will create an “aggregate audio device” on macOS, which can cause issues in some cases. The team is looking into this further, but in the meantime, I recommend that you use the same device for Main Ouput and Pre-Cueing.
Because I play in clubs where I need a powerful sound I preferred to buy a good audio interface (SSL 2) rather than using the main output of FLX4 which I do not find it very powerful… Another option would be to use SSL 2 both for main output and for pre-cueing (since there 's a headphone plug in SSL 2) but when I use SSL2 as my main output, I don’t see it in the pre-cue ing scroll down menu of djay PRO software! In other words I can use SSL2 either for main output or for pre-cuing, but unfortunately not for both at the same time!
Understood. Thanks for the additional info. Well let’s see if the engineering team is able to uncover anything useful in the sample process you capture…
This is the link of another sample process report session in which again approximately 1.5hrs later the headphone sound problem occurred again:
In terms of using two different sources for main output and for pre-cuing, I used to do this in my old MaC (2010) until one year ago. I was using Traktor A6 audio interface as the main output and FLX4 for pre-cuing but never experienced such a problem.
For the current situation it’s really interesting that after the problem occurs if I change the pre- cue source to something different (macbook speaker for example) and switch it back immediately to FLX4 again, the problem is fixed. The problem with that solution is that when you do it, a one second cut occurs in the main output sound i, every time I change the source of pre-cue ing.
I wanted to share this info with you, so that it might help!
Thanks for the additional sample process and info @Aleksandros_Panayoti. I’ll share this with engineering.
Hi @Aleksandros_Panayoti, while aggregating audio devices usually works fine, some combinations of audio devices can be unreliable e.g. if they don’t support the same sample rates or if their clocks can not be brought in sync. That being said you can try adjusting the settings in the “Audio MIDI Setup” system app to see if that helps:
  1. While djay is running and configured with an aggregate device, select the “Aggregate-Audio-Device” device in the “Audio Devices” window of Audio MIDI Setup.
  2. Try disabling “Drift Correction” for one or both devices that are being aggregated.
  3. Try adjusting the sample rate of the aggregate device.
  4. Try changing the “clock source” of the aggregate device.
I hope that helps!
Hi again @Aleksandros_Panayoti, please try the steps shared above as this seems to have solved a similar issue for another user:
