Hello,
I have a question, I need to control 4 decks and cue headphones with Djay Pro, it is possible with PIONEER DDJWEGO2W ? The output and headphones will be in stereo?
Hello,
Hi Dani Valle,
4 deck mode is not supported by the WeGo2, sorry for that.
In 2 deck mode the outputs and the pre cueing will be in stereo.
I hope this was helpful.
As Dysfunk DJ said, the Reloop Mixon is capable of 4 deck iOS control.
Cheers,Lukas E.
The Mixon 4 is the only 4 deck controller which is supporting all 4 decks of djay Pro.
Reloop mixon
Others may come out but who knows really.
Thanks,
Do you know which device can we use to mix 4 dect with IPAD ?
Best regards
Is the only one can work 4 deck in IOS, some cheaper alternative?
Thanks to All.
I have the Wego2; wouldn’t hitting the Deck C and D buttons allow you to control 4 decks? Or am I missing the point?
