I would like to use Djay 2 for my wedding. I would like to have a simple set-up to automate a mix of songs with criteria that I set. For example, I would like a playlist of the songs I want set it up to mix every two minutes or so and it will just go through and mix them all together. Does anyone know how to do this?
Djay Pro has this feature in Automix Configuration menue. But the transition is unpredictable. Sound not always good.
Hey Kara,
you can set the Trigger before End Time in the Automix settings to enable faster transitions between tracks.
Have you found the feature?
Ok, thanks! So I just downloaded djay pro then. Do you know where in the app I can do that?
