I m trying to map the pioneer wego. I want to use an FX button to launch FX1(easy - enable FX1) and later I want to control the parameters using the jogwheel. So I am using the midi out setup and selecting the note on/off. I am moving the jogwheel for learning but I get 2-3 extra controls…from here… pls help, do not know which one to choose/setup etc. Tried several combinations.
anybody can explain the extra controls functions, selection? I am new to midi mapping.
If you drop that into your Midi Mappings folder (~/Music/djay/Midi Mappings/) it should work the next time you launch djay.
Once you turn on the FX button, the jog wheel changes the parameter, holding down shift with the jog wheel will change wet/dry. Jog wheel goes back to normal when FX button is disengaged.
