Hercules DJ Control Inpulse 300 Android
I have a Hercules DJ Control Inpulse 300 since nearly two years.
Now i was searching for a opportunity to use this with a chromebook.
Your software is great and i am using it for about half a year on windows but now i figuerd out that there is no native support in the android app for the Inpulse 300.
It’ll be great if you can add this :slight_smile:
