Is there, or can anyone provide, a midi mapping file for the Hercules Jogvision please?
You can map it in djay pro.
if you are having troubles with the mapping please contact the support via support@algoriddim.com.
They can help you with the mapping.
Hi thanks for that Ivan.
I am aware of the midi mapper and have tried to map each control.
But unfortunately most of buttons still don’t work…I’m even having problems with the cross fader.
So has anyone managed to successfully get a fully functional map??
Hello,
The Djay Pro map for DJControl Jogvision is on Hercules support website
https://support.hercules.com/en/produ…
In the section MIDI Mapping.
