Without needing to manually place a new song on a new deck and press play
Hey there,
just like Victor Damian said, have you tried the Automix?
Also if you have any questions regarding djay Pro for the Mac, please check our Manual (cmd + ?).
Hey ChrisM,
can you tell me which version of djay and for which device you are using?
Cheers,Lukas E.
How do you control which Playlist automix will pull songs from. every time I turn it on it pulls random songs from Spotify. Not my playlists
Djay pro for iphone
Yes simply use the automix function. You can tailor the mix to sound like a blend or just play one song after the other.
