Hide and unhide playlists
Would love to be able to only show the Playlists that will possibly be used for the current shows or session, hide all the rest but able unhide as needed.
Hi @DJ_Noside, Thanks for the suggestion! I’ll share this with the dev team for consideration.
Here’s what works for me:
I make a folder for every venue and only work from the playlists inside it or just the folder itself. one of my current residency gigs has the early part of the night with open format, but later it’s all Hip-Hop and R&B and a bit of throwbacks.
I’ve built a massive playlist of over 3,000 songs for this venue alone. Having everything in one place means I can just freestyle directly from that list, confident that any track I pick will work for that crowd.or i can run thru sets form other nights also in this venue folder.
Thanks for sharing @Owe_Marley. I use a very similar workflow!
