Mid & Low Eq on both channels using the controller both register as MID on DJAY?
Hi Andrew,
Please open “Configure…” from the “MIDI” menu and make sure that “Built-in mapping” is selected.
Can you please send a screenshot of the menu? Thanks!
Make sure to open the drop down menu for the screenshot.
Hi Andrew,
Sorry for the late reply. I somehow didn’t get notified about your last post.
Please click on the drop down menu next to “MIDI Configuration” and select “Built-in”.
Hmmm. Please open Finder and go to this folder:
/Music/djay/MIDI Mappings
Are there any files in this folder? If yes, please delete or move them to your Desktop and then try your controller again after retorting djay.
The VCI 100 does not have a built-in sound card, so you’ll need additional hardware for pre-cueing. You can either get an external audio interface (USB sound card) or get the Griffin DJ Cable.
For better sound quality, I recommend getting a (multi-channel) USB sound card.
Please open “Preferences” from the “djay” menu, go to “Devices” and set up your sound card. For example:
- Main Output:
- Pre-cueing: Built-in
In this setup, you need to plug in your headphones to the Mac’s headphone out.
Thanks for the reply, I cannot see any built in mapping to select, under this menu.
Ta
No reply
Speaker for my Mac I’m using KRK Rokit 5 don’t know whether this will help?
Hi
I deleted these files but still no change
Anything else I can try?
OK, using the hardware above to cue the next track in headphones do I need to purchase a lead?
Please reply
Hi
I have an audio interface sound card to run KRK Rokit 5 speakers with my MAC, but still cannot pre cue using headphones. I think I will have to get Traktor and start again.
Cheers
