I recently recorded a 3 1/2 hour set at 408mb but it won’t play through itunes. Is there a limit to the size of recording you can have?
Hi John,
There’s no limitation in djay. The only limitation comes from the amount of free disk space left on your device.
Do you have a Windows PC or a Mac?
I have a PC but loads of space left. Seems a bit weird. The file type is all the same etc. it works out at 408mb
