how can I choose to play partial song in automix mode?
I am host of the party. So I want to use auto-mix mode. I dont want djay app to play full song before it starts the next song. Is it possible to play only 60% song?
Hi Manmohan,
thank you for your post.
Could you tell us which version of djay and on which device you are using it, that would be nice to help you out.
Hi Manmohan,
thank you for your information.
I am sorry to tell you but there is no feature where you can set the start of the Automix transition to a percentage of all songs. You could try to work with the “Trigger before end” settings, which allow you to start the Automix X-seconds before the end of the song.
Thank you very much.
I am using Djay 2 app on iPad mini. But I have iPad pro as well as Mac Book also at home.
Thanks for quick reply.
