How can I create a mix with each song only 2 minuets long
I would like to create a mix where each song transitions to the next after two minuets of play time
Hi Von,
Which app do you have? This is only possible on the Mac version. Go to “Preferences” -> “Automix” and select 2 minutes for “Maximum Play Duration”.
