Failure of Djay program to sync/work with JBL wireless speaker
Hi Warren,
Thanks for contacting us.
Are the speakers connected via Bluetooth? Please try the following:
- open “Preferences” from the “djay” menu
- go to “Devices”
- check if you can select your speakers from the drop down menu for “Main Output”
