When using an Audio Unit Plugin the plugin sits on top of Djay 2 Pro. I can move it to side of screen so it don’t take up place but is there a way to hide (not close) the plugin?
I’ll do, thanks!
Hi Kim,
could you please contact our support via support@algoriddim.com and please provide them the following informations:
-Which device do you use for djaying
-Which OS are you using
-Which djay version are using
Thank you very much, we will help you as fast as possible!
Keep it up,
