I have had no success in controlling ivj with the Ida pro. They are suppose to be compatible. Please help!
Sorry to hear that.
Which iPad do you have? Also, which vjay version are you using?
In case you also have djay on the same iPad, please check if you can use the iDJ Pro with it as an experiment.
