I’ve made a recording in Djay2 but I can’t load it onto both decks - whenever I load it it goes to the left hand deck only. I know it is possible because I did it once before but now it is not working!!
Glad you figured it out!
By the way, if you press load, the recording will automatically be loaded on the inactive deck, which mostly means the deck on the opposite side of the crossfader.
No worries - I worked it out. Thanks for al the help lol.
Hold down the load button and select double. Just me being foolish!
