Right now i can’t see which effect i have selected when I’m mixing, it is very hard to learn the exact order of all the effects and it would be great if you could just see on the screen which one is the current.
Using Djay 3, you can see 3 effects in the main screen, when you use the Pioneer Wego3.
Whitout a controller, you have to push the “button” with 3 faders and select fx.
Hi Fredrik,
As we’ve discussed via Email:
Once you tap the Tools button and select “FX”, you can switch between “PAD”, “INSTANT” and “MANUAL”.
