i just recently bought the djay software for my mac to use my unmark mix deck, however it doesn’t automatically configure like most softwares do and when i try to configure it myself it seems almost impossible to do. i need some help here. how do i configure my mix deck so i can use this software i am excited to use?
Hi Bucky,
Which app and which Mixdeck do you have exactly?
im using the DJay app for my mac, and im using the numark mixdeck
