Greetings all. Is there a way to adjust the echo out effect where the tail only allows the highs to go through? Or, is it set in stone in the software.
Hi @DJ_A_Diffrance, try selecting the Manual FX, Echo Out, then set the Routing to Drums and Bass.
Thanks Slak_Jaw. These are great tools, indeed. I’ll need to figure out the workflow, and how to achieve the effect I’m looking for. I was trying to find just a frequency slider or something.
You’re welcome @DJ_A_Diffrance. Happy to help. Hopefully you find the workflow you’re looking for here.
