I’ve got mountain lion and many airplay devices.
I does not work.
Anybody knows a trick?
If you have more than one AirPlay device in the same network:
- Open “Audio MIDI Setup” app and select “Show Audio Window” from the “Window” menu.
- Click on AirPlay in the left tab.
- In the right tab, there should be a dropdown option where you can select the desired AirPlay device.
Thank you. Works fine
(with some troubles with passworded airplay devices).
I wish djay would play over all airplay devices not one only. If so it could successfully replace iTunes DJ with it’s sound Automix.
Since issuing djay remote for iPhone/iPad I believe that it is a logical next step for.
I have no data but I believe that people using their macs as music servers usually cast the music over more than one airplay device.
Good job anyway
I totally agree with Tomasz, for sure…
Can we have an idea of when Djay will be able to stream to more than one Airplay device (base of multirooming I guess…) ?
