I have used djay2 on iPad (with Vestax Spin controller) for a while with outstanding performance and low latency. I recently installed djay Pro on Windows 10, and noticed some latency. How do optimize Windows 10 for best realtime DJ performance and low latency?
Hey there,
keep the amount of background programs as minimal as possible. Also have you tried using the exclusive mode which you can find in the audio device settings?
Cheers,Lukas E.
Hello,
Close programs running in the background.
I 'v installed the Windows 10 Creators Edition. Now i"m testing Djay Pro in Gaming Mode. This should free up more resources.
I also tried to set the priority of djayPro.exe to “RealTime” in Task Manager.
No I haven’t tried that, thanks!
