Is it possible to preset/start all songs, 15seconds after beginning and end them 15seconds before end, in Automix? This is to keep as much of the original song(not a fixed interval,eg 2 min or 3min) But most importantly to avoid lame starts or endings in upbeat songs.
regards Joakim
Hi Joakim,
You can use the “Start transition x secs before reaching end of song”.
There is currently no global setting for the beginning. You need to set a “Start Point” for each song and then enable “Use start and end point…” in the Automix settings.
thanks, I wonder why its not possible to automate beginning eg15sec into the song? maybe the automator in my mac can do it!
