How to solve Apple Music playlists gone?
If you are unable to solve the problem of Apple Music playlists disappearing, there is a reliable way to help you permanently keep all Apple Music playlists in your database without being deleted after subscribing. The ViWizard audio converter can decode protected Apple Music files into MP3, AAC, FLAC, M4A, WAV, and M4B. In addition to Apple Music songs, iTunes audio and Audible audiobook can also be converted using this tool. Once all Apple Music songs are unprotected, you can permanently keep all songs and playlists in the Apple Music database, even if you later stop subscribing to the service.
Step 1 Import Apple Music to ViWizard
Step 2 Choose Output Format
Step 3 Convert Apple Music to Common Format
Then you can keep all these converted Apple Music playlists on any device as you like and will never lose again.
